My operator is Movistar I have problems with signal with my Sony xa1 ultra the signal is very weak with only two bars in 3g I do not have internet .. and the calls are of poor quality. I have changed the same chip from the same operator Movistar to another computer an LG Xpower the signal works well the internet runs well the same is with the signal. I did not think that Sony xa1 ultra cell phone is not so powerful
Mi operador es Movistar tengo problemas con señal con mi Sony xa1 ultra la señal es bien débil con solo dos barras en 3g no tengo internet.. y las llamadas son de mala calidad . He cambiado el mismo chip del mismo operador Movistar a otro equipo un LG Xpower la señal funciona bien el internet corre bien igual es con la señal. Nosé que pensaa que celular Sony xa1 ultra no es tan potente
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Could you check the signal strength on both devices?
Settings > system > about > status > SIM status > Signal strength
Also, could you test a different SIM card (different operator)
I'm facing the same problem.
Can you help me with this?
