Process system isn't working .. Xperia XA1 plus
Binhwang
Visitor
Since i update to android 8.0,i used got error "process system not working ". I tried to repair by sony companion or reset factory but everything still the same. Fix it.... ..  .please!
61 REPLIES 61
santhire
Visitor
Any admins reply here with solution.. Even i am having issue
LuzCamarena
Visitor
Tengo el mismo problema que todos los de aquí, a partir de que actualicé el sistema a Android 8. Me aparece a cada rato que el proceso del sistema no funciona. ¿Qué hago? Eso no permite trabajar ni el uso de las apps y tengo más de 20 GB libres.
I have the same problem as everyone here, since I updated the system to Android 8. It appears to me every time that the system process does not work. What I do? That does not allow working or the use of apps and I have more than 20 GB free.
gt
Batmansiako
Visitor
Lourdee
Visitor
PROCESS SYSTEM ISN'T RESPONDING 😭☹️😞
Lourdee
Visitor
I keep getting this system error. I bought this device out from hardwork. From the little savings I have to price myself. Instead of giving happiness and satisfaction, it gave me stress instead!.. ☹️ The phone screen always malfunction. 😭😢
Lourdee
Visitor
Now, the screen always malfunction. Keyboard also is not functioning well.. Haiiiiist tsk tsk ☹️😭
rengare
Visitor
same bug , it popups very frequently, latest update did not fix it either.. we need a stable oreo this is frustating 😔
build number = 48.1.A.2.50
profile.country.US.title
Qatrium
Did anyone try to perform a software repair using Xperia Companion? This will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
Lourdee
Visitor
Hi, Rengare! ☺️
How's your day? I hope all is well! I tried to hard reboot my device.. I still encounter the error msg but not the frequent as before..
rengare
Visitor
hi , here is what I found in,
developer options > take a bug report
when I check it i found drobbox crashes in background i tought this might be the issue so I installed the beta version and restarted the Phone, unfortunately, it again gave error at some point,
now I uninstalled the drobbox so far so good but we will see is it gonna hapen again,
EDIT 1: ok it is happening again ,maybe dropbox is not the issue 😔 the bug report is comlicated to read it is Around 17 mb txt file 😂😂
