Process system isn't working .. Xperia XA1 plus
Binhwang
Visitor
Since i update to android 8.0,i used got error "process system not working ". I tried to repair by sony companion or reset factory but everything still the same. Fix it.... ..  .please!
61 REPLIES 61
Jazz911
Visitor
Anyone found solution?? Does clean install through pc companion works?? Please reply
rengare
Visitor
I did a software repair With xperia companion, and the problem still exist even with clean install, my Sony experience is very bad 😞
Jazz911
Visitor
Thanks for reply rengare bro.. You have saved my time Slightly_smiling_Face
Please look into this problem, if any moderate is here..
adela1
Visitor
Hi there,
I have updated today my XA1 plus to the latest version of android (as it request). Since then I can only restart/shut sown/screen pic . I can't even unlock the phone so I can't use Xperia companion .
I've got plenty of space, and it does the same on safe mode.
How can I repair it ? I'm afraid to loose my data and can't even backup it.
rengare
Visitor
hello  people I changed my simcard and in last 3 days I only got 2 error, one for ZEDGE has stopped working at background, and the other one is system ui has stopped working, so far so good, my old Sim card was 8 years old,  so if your Sim is old too try to change and please give here a feedback about it,, so we will know this problem comes from old Sim cards or whatsoever  have a nice day
Edit :
okay it has been a week and the system process not responding error unfortunately continues where it is left from 😂😭🤬
MavzTh3Machin3
Visitor
Any solution? My phone is 2 weeks old...wtblueblazes?!!
NewtonAtari
Visitor
Same problem here Happens continuously and is a new device has no more than two weeks
Jazz911
Visitor
I have to restart my device at least 2 times a day to get rid of this error... please solve this problem ASAP... Crying_Face
KiranAK7
Visitor
There is no permanent solution from sony until now,its sad But here is a work around which will fix it temporarily for some days or weeks Bring the powermenu by holding power button then,longpress on "restart" option until it restarts by itself,it will now enter "safemode" then again just normal restart your phone, problem will be solved for some days or even weeks. Repeat the same until sony fixes it
KiranAK7
Visitor
This is the only SOLUTION until sony fixes it.THAT'S IT.
THE END.
