Hi @Kylesonnen, welcome to the community. I am sorry to hear you're having troubles
Just to clarify the issue, at the moment your power button is not working. Is that correct?
Will it shut down if you do the button combination (power+volume up) anymore or no?
If not, you'll probably be best to contact your Local support team as this will be a physical issue.
