- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi - I have the XA and recently it 'may have been dropped' - (daughter wont admit!) however since then the touch screen is totally unresponsive (is in a protective case) Using the controls on the side I can do volume / the power off/screenshot image etc but cannot actually do anything as the touchscreen isnt working. No obvious signs of damage ie cracked screen. I allowed it to run out of power and when I charged it same problem persisted and back of pack got very warm.
Any help appreicated , or does it need sending off for repair? Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
have you tried safe mode? you can navigate the screen using an usb OTG device. like a mouse..
if it still doesn't work, you can try to save as much as data you can, then send your device to your local service center Local support
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So now, the problem is if the display is totally unresponsive you won't be able to access safe mode easily.. Do you have a USB mouse and an adapter from USB to micro USB.. You will be able to control your phone with it...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Safe mode made no difference - couldnt access any data but its now at repair centre - thankfully I hadnt had it long so not going to lose too much stuff!!
