Xperia xa screen mirroring problem
Ravi77
Visitor
I m tired to screen mirroring with my samsung smart tv i resat my phone but not work
Tags (1)
19 REPLIES 19
Uliwooly
Jake-SonyXperia
Champion
Hi Ravi77,
Have you made sure that the Samsung TV has Miracast functions? If you are unsure it is best to contact Samsung directly to find out.
Ravi77
Visitor
Yes my tv have miracast function
Ravi77
Visitor
My t3 connected with screen mirroring with same tv
Jake-SonyXperia
Champion
Can you advise what happens when you go through the process are you getting some form of error message?
Ravi77
Visitor
When i press start button than my tv show loading and than my phone show screen mirroring off and tv show disconnected
ravi7477
Visitor
I've been trying to get the screen mirroring function to work. The phone detects the TV, and the TV says the phone is connected - but then the phone says something to the effect of 'starting screen mirroring' - it comes up with text that seems to indicate that the pairing has initialized, and a split second later you see a message saying screen sharing has ended on both the TV and the phone. It does not actually display the screen for even a second before disconnecting.
Christofer
Champion
Which TV model is it that you have?
Have you checked if your TV is updated to the latest available software? If it isn't I suggest that you update it and then test this again.
ravi7477
Visitor
My tv is up to date and online customer care suggest me that you repier ur software I repier my software but after that problem is same I go service centre but problem is same my screen mirroring is not working so now my question is that can Sony exchange my phone or not.
