3G not work after upgrade Sony Xperia L to Android 4.2.2 version
msingh
Visitor
Hi Everyone,
I have upgraded my Sony Xperia L (C2104 model), after upgradation OS & build version as below.
Android version - 4.2.2, Basband version - 8930B-BAAAATAZQ-3228109-08-0031
Kernel version - 3.4.0-g74b701b-00042-ged52e3b-dirty, Build version - 15.3.A.0.26
after upgrade i am facing an issue with 3G, only 2G connection is working. when i have selected WCDMA only or WCDMA (preferred)/GSM mode than 3G connection totaly lost showing red cross sign.
Even i tried to add new APN settings from airtel customare support, my APN settings as below.
Settings --> more --> Mobile networks --> Access Point Names
APN Name - MI
APN - airtelgprs.com
Proxy/Port/Username/Passsword/Server/MMSC/MMS Proxy - Not set (Default value)
MCC - 404 (Default value)
MNC - 10 (Default value)
Authentication type - None
APN type - default
APN/APN roaming protocol - IPv4 (Default value)
Bearer - Unspecified
and also download APN settings from below options
Settings -> Xperia -> Internet Settings, but all these changes are not resolve 3g connection issue. This same issue was facing my colleague with Sony experia Z handset.
I am requesting to everyone & sony suport expert, kindly help me to sortout of this 3g connection issue.
Thanks in advance
Regards,
msingh
14 REPLIES 14
ariff95
Visitor
I found the answer...u have to do the factory data reset roght after updating your phone to 4.2.2..it works...i did tried on my phone now
Kakavouras
Visitor
After i update my xperia L c2105 to firmware 15.3.A.1.14 my 3g dont work at all.I make factory reset 10 times.I use pc companion to fix my firmware 3 times.Nothink can fix that problem.What can i do?
mosdim
Visitor
Kakavouras, try to manually add APNs in mobile network settings
Guido1979
Visitor
Ok, it seems to be working for me right now.
I did contact Sony. They senden me this link: http://www.sonymobile.com/nl/tools/%20update-service/
It's Dutch but you'll figure it out easily. After everything was downloaded and unpacked you start the Update Service and select your device. Then it will go back to the factory settings but it will not delete 4.2.2.
Here's the trick with my phone, i have the C2104 but when i did that, nothing was changed, still no data traffic.
Then i did previous steps again but i selected the C2105 and now it works. Hopefully tomorrow also but that was my problem.
I hope i helped you guys with this, good luck!
PS: My alias is different but i am the smae poster as Guido in previous posts.
271997
Visitor
when sony Xperia l C2104 update to 4.3 or 4.4.2?
