Arabic
jordaninegypt
Visitor
Arabic
Hey
I have an Xperia Z2 Tablet.  The problem is enabling Arabic.  Apparently there is no support for Arabic on the version of the tablet I bought from the United States.  I downloaded an Arabic keyboard for onscreen, but I also have a physical keyboard that seems to require support from the Android operating system.  Can anyone advise me on how to get Arabic up and running on this tablet?
Thanks,
J
2 REPLIES 2
gamalmostafa
Visitor
I bought Z2 tablet from US and it supports arabic.
jordaninegypt
Visitor
Can you confirm which version of the operating system you have?  Can you also tell me if you had to install an Arabic keyboard or if your tablet's operating system came with one installed.  The problem is that I don't have native support.  I installed a keyboard but I can't use it with the physical/bluetooth keyboard for some reason.
