Audio way out of sync when recording 4K video
baldwin471
Visitor
I've contacted Sony about this and they told me to factory reset and connect it the the PC to "repair it". After I did this the problem still exsits. The audio is noticeably at least half a second before the movement of the mouth. I recorded a video and you can see here - https://www.youtube.com/watch?v=t2yepQ6aYwY
It's quite annoying. Especially after being told by a Sony customer support person that they aren't even aware of this as a problem.
11 REPLIES 11
Uliwooly
Do you have the latest update
settings > about phone
which build number do you currently have?
baldwin471
Visitor
I believe the repairing updated the phone.
Build number is - 17.1.A.2.55
Uliwooly
http://www.sonymobile.com/global-en/software/phones/xperia-z2/
Android version: Google Android 4.4 (Kitkat)
Latest available software: 17.1.1.A.0.402
Release started: 2014-05-23
baldwin471
Visitor
Not available.
Uliwooly
it has to be approved by either your carrier/network or in your region.
baldwin471
Visitor
Well I have a UK Sim-free unlocked handset. I would've though those would be among if not the first to get any update. Then again, since the HTC M7 Sense 6 update has been out for 3 weeks and people in Albania are getting the update before me, I guess I'm just unlucky.
Kolumbas
Visitor
I had the same problem with my Xperia Z2 but the newest software update 17.1.1.A.0.402 fixed all the problems. I am so happy I can film 4K without any problems now:)
Uliwooly
In the UK it seems to be a bit different, in the sense that carriers/networks have to approve the update even for unlocked phones
baldwin471
Visitor
So what is the situation for me then? I have an unlocked Z2 from the UK but I'm using it in Lithuania, on Omnitel, a carrier that doesn't sell the Z2. Will I ever get the update then? Or do I have to wait until I'm using a UK carrier sim inside of it? What a ridiculous way of doing things, Sony. That's kind of the appeal of buying sim-free and unlocked, you normally get faster updates than carrier models.
