battery drain
SyedTalib27
Visitor
battery drain
I have Xperia m with jelly bean 4.3.The battery lasted very long while using 2G but recently i have moved to 3G and i find that the battery is draining very quickly it only last half of the time when compared to 2G,does this happen to all
10 REPLIES 10
TalkingHead
Visitor
The following is the battery siginal indicator strength as seen in settings->Power Management->Battery Usage
Tap on graph is see history details.
The Mobile Network Siginal will be one of the following where 'yellow' is bad and green is good.
signal strength color codes
Even with applications 'closed', many will continue to run in the background.
These applications, like news feeds, email and social media will continually 'wake' the system up to check netwrok/data/status updates. If these applications are poorly written/set up, they can quickly drain a battery.
Also having Bluetooth, GPS and location services always on, also use battery.
Just a few things to consider.
