Camera focus Z2
draz3n
Visitor
Camera focus Z2
Hello my camera on sony xperia Z2 cant take a focus on pictures which are in some distance but it doesnt have a problem to focus when im taking photos of objects which are close for example documents. any suggestions?
9 REPLIES 9
profile.country.RO.title
_alexdon_
Have you tried to use superior auto or manual mode with HDR enabled?
alexdon
draz3n
Visitor
i tried with manual hdr and its still blurred, how i can check hdr in superior auto?
_alexdon_
In superior auto,you cannot edit the settings too much,HDR will be enabled depending on the shot.
alexdon
draz3n
Visitor
camera on front is taking better pictures.... should i reinstall software?
_alexdon_
Have you tried to set the back camera on higher resolution? For example 20.7 MPx.
You can try a software repair.
alexdon
draz3n
Visitor
its weird cause i tryed manual on 8mp and 20.7 and didnt see any diffirences....
_alexdon_
Perform a software repair and see how it is after.
alexdon
draz3n
Visitor
i restored system and still same problem
_alexdon_
In this case,stop by a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
