Cant Starting after upgrade and installed software
jhoney
Visitor
Hello
I was bouught this Sony Z Tablet 2 days ago
Then today i was updated and installed some program
When i installed and updated the sony software, ask to restart.
But till now the phone cant start up or unable to lit, still blank screen
Please advise how to trouble shooting it
Thank you
juliet
5 REPLIES 5
Thommo
Genius
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Switch off your tablet and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your tablet still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
jhoney
Visitor
hello
still not work
was update this program then when ask restart it wont restart again
17.1.2.A.0.314
Please advise
Thank you
Thommo
Genius
Did the repair complete successfully? If it did and you are still facing the same issue then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
jhoney
Visitor
the upgrade software ones was sucesfully before asking restart
and the repair issue still unsucesfully
so what should i do
please advise
thank you
juliet
Thommo
Genius
As above you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
