compatible headset for xperia sp
poojit
Visitor
Can you please tell me if 'Apple MD827ZM/A In-the-ear Headset' is compatible with Xperia SL?
4 REPLIES 4
Hampus
Champion
Sony Xperia SP uses the 3.5mm CTIA standard. Unfortunately we cannot guarantee that a headset from another manufacturer will be 100% compatible with the phone. If the headset follows the CTIA standard you will be able to hear the music but if the headset have play/pause buttons these might not work correctly.
More information regarding the CTIA standard can be found in our FAQ:
http://talk.sonymobile.com/t5/FAQ/Problem-using-headset-accessory-not-supported/m-p/347872#U347872
DRWHO73
Visitor
CAN YOU TELL ME WHY YOUR SONY EARBUDS ARE NOT COMPATIBLE WITH SONY XPERIA SP
DRWHO73
Visitor
poonster
Visitor
Turn the volume fully off on headphones before you plug it in. Well it worked for me
