conection problem
alleon
Visitor
conection problem
Hi i have a problem with my xperia z1 with dualshock i made many times the conection with USB cable and it cant be conected. I would like to know how can i do it?. And if maybe its a problem with actualized softwared because when i bought the xperia Z1 the software was 4.4.2 android and now i get 4.4.4 and my xperia cant conected with my doualshock PS3. please help me i would like to get this opportunity thanks my xperia by SONY let it this conection...
3 REPLIES 3
Alexander1
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I would suggest that you first of all try to connect your Sony dualshock 3 to the phone using another USB OTG cable to see if you are able to connect the controller to the device.
alleon
Visitor
Hi i cant dualshock ps3 conect to my playstation 3 yet. i tried different usb cable. can Anybody helpme? some tecnical person will be able to helpme? are you sure that it wont be the software actualized? ill hope for some answer thanks...
Alexander1
Champion
If you can't connect your dualshock 3 controller to your Playstation 3, I would suggest that you search for help at the Playstation site: http://playstation.com
