hello
im in need of some serious help.
myy Sony Experia z will not switch on and i dont know why. i have tried all forms of ways reccommended on the Sony website and also tried using PC Companion to use the software update for phone service but it does recognise my usb conection.
please help me or recommend a way for me to fix this problem as soon as possible.
P.S i took my phone to mtn and they want to charge me R5500 to fix up this problem while my phone is still under warranty . this is unacceptable.
i would prefer direct aid from Sony.
Thank you .
Try to perform a system repair
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
To add this is a user support forum so the direct aid you speak of will be from your local Xperia care team http://www.sonymobile.com/global-en/support/contact-us/
