Forgot Pattern lock
Jdas
Visitor
Forgot Pattern lock
I forgot my passcode is there anything I can do to go back on I have an sp
1 REPLY 1
Thommo
Genius
The only thing I can think of and know to work is to perform a system repair - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
