Sir i have all the no. without imei no. How can i get imei no?
I have lost my phone.
Do you have the box? Search on it.
There are multiple ways to get your IMEI
1- Look on your box
2-Open the micro sd card slot, remove your micro sd card and pull out the plastic tab inside.
3- Go to settings, scroll to the bottom and select about phone and then select status and scroll down to IMEI
Oh, i see you said you lost your phone, the box is the only option then.
IF you no longer have the box or receipt, you'd best go back to where you purchased it and see if they can reprint it for you.
You may manage to get your IMEI number from where you purchased your Z2 or from your Service Provider
Hope this helps......
@malt1977 wrote:IF you no longer have the box or receipt, you'd best go back to where you purchased it and see if they can reprint it for you.
Sorry......you type faster than me i guess
haha ok im just trying to get a sim card activated and its askin me for a serial number is that the same as an iem
*imei
