Latest Update Issue
technicalblack
Latest Update Issue
My Xperia Z2 updated last week and since then I've found that three in every four or five calls that I receive simply gets cut off when I swipe the screen to answer. They don't get sent to my answerphone and the number doesn't get added to my call list meaning that it's lost forever. It's so unbelievably frustrating as some callers just don't call back and I rely upon my phone for work. Has anyone else had this problem since the latest update? Any idea how I might be able to fix it?
Many thanks.
1 ODPOWIEDŹ 1
Thommo
Genius
I alaways after an update perform a full system repair - I often find that updating can cause some albeit very slight issues - If this is something that you want to do then I'd advise you backup all files etc 1st as a system repair will erase all data ie: Taking your phone back to factory state with the latest firmware installed
