micro SD card unexpected unmounting
DanielOchoa
Visitor
Hello everyone,
I'm using a Xperia Z2, and it keeps constantly unmounting and mounting the micro SD card for some reason.
My SD is shown below, and it worked perfect in my old Xperia T.
I've "quick" formated it a couple of times, and didn't work. Then I "fully" formated it and same outcome.
The file system used is exFAT.
It might be worth noting that 39Gb are used.
Also, every time the card is unmounted it modifies the properties of my music files and erases their information; when I go to my "artists" in the Walkman App, the amount of unknown artist songs increases.
Does anyone have the same issue? Can anyone help me???
Tags (3)
2 REPLIES 2
profile.country.RO.title
_alexdon_
malt1977
Visitor
Are you able to tell if the card is genuine? This may not be the issue as you mention that it was fine in your old handset, but it might be worth looking in to.
