Hello,
My Xepria SP is dead and when i press power on transparent part in mobile blinking RED
i charged it using wall charger and also blinking but no power on
Help plz
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
If it blinks red when you try to power on the phone, it sounds like the battery is completely flat. I would suggest that you connect the phone to the charger and let it charge for 2-3 hours. You can also remove the back cover and you will find an OFF button which you can hold down for 5-10 seconds.
