myXperia draining battery
Arnavzz
Visitor
Hi,
The myXperia app is draining the most battery in my phone, I have turned the GPS off and also deactivated myXperia from security settings but it consumes the same amount of battery time under the GPS title as the phone has in total discharge. Meaning if the phone says 10 hours discharging, the myXperia app shows GPS on time as 10 hours, however my GPS is off for sure and myXperia is also deactivated under securtiy.
How do I completely stop the myXperia service? Any help?
Tags (2)
10 REPLIES 10
Rickard
Master
Please make sure that you don't have a computer that's logged on to http://myxperia.sonymobile.com/. This would keep the tracking and GPS enabled.
If you don't have any computer that's logged on, try clearing data for MyXperia under Settings -> Apps -> All and then restart the phone.
