hi im new hear this is my first post.......i have no auto wifi swiching, i can swich it on/off mannuly ,it used to auto swich but not now,,ive tryed evrey thing i can think off, ive even tryed a the marster resett my phone is xperia sp c5303.....android version 4.3...build number 12.1.a.1.205.........can any one help please.......pip57
Yes,you have to enable wifi by location in power management.
hi i thank you for your reply, but ive tryed that but it dose not work.ive tryed evrey thing i can think off, ive even been on play stor and tryed apps to the job, but NOTHING works......
thank you for the link,,,,,i will go their, but i dont expect much luck,....ill let you know what happns.......pip57
Good luck.
hi i have that software ,but cant update it, connection error with the interner
Disable the firewall or add pc companion to exceptions.
i am now stuffed, compaion no longer works,i just get a message to say it needs to be updated,when i do it says instelatoin error, and im forsed to close it........thanks anyway.....this is now a throw away phone......wish i had never botherd with a sony phon...pip57
just read your post,,,,,illl give it a go
