hi i can not get the mail to the bootloader code (xperia s)
email:
This is a user support forum so we have no way to help you with your code - If you want root then use Towelroot then install SuperSU from the Play store and reboot
supersu already installed
I can not install the bootloader unlocked mail does not come off he cwm
You will just have to wait for the unlock code to install CWM but if you just want root so you can use Titanium backup then Towelroot will do that
