NOTICE ME PLEASE!!!!!
marielmagnaye
Visitor
I cannot turn on my sony xperia after charging it to a powerbank. What can i do to fix this problem? I need your response as soon as possible, please. Thank you.
1 REPLY 1
Thommo
Genius
Try holding power and volume up untill it fully switches off then try a restart and if that fails
then you may need to perform a system repair which will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
