My xperia M just won't charge, it's not the charger as it works on other devices and other chargers have no effect. I used to have to hold it at a certain angle now it just doesn't charge and it is dead. I think it might be the port on the phone. Please someone help!!!!
Does the USB transfer work with the same cable?
What's the usb transfer?
How do you normally charge the phone? With a cable where you connect the adapter,correct?
So you say the cable works fine with other devices?
Yes correct
In this case,just contact your local sony:
http://www.sonymobile.com/global-en/support/contact-us/
They should be able to help you.
