Power Button Restart
vickyfayad
Visitor
The Power Button of my Xperia ION is broken, actually new phone will a5rrive within 3 days but I need to be available till then. Somebody can advise how to switch on the mobile without powerbutton??
thx
2 REPLIES 2
dm841
Contributor
i doubt there's another way to do it best way is connect to coputer while holding down the power button and hoping it works
Thommo
Genius
That won't work as it will only enter the phone in to Flashmode - So there is pretty much nothing you can do apart from taking the phone apart and check the power button connection cable or even trying to short it in to think the power button has been used, Would I advise it, The answer is no unless you know what you're doing
