Power Management Bug
a2k22010
Visitor
Hi all,
Off late i have been noticing the below bug.
My battery usage statistics was showing Wifi to be always consuming power. I was surprised and hence wanted to test.
I turned off my Wifi at 10PM. When i checked the battery usage statistics (clicking in to the graph), the next day morning it was showing that Wifi was using battery the entire night.
I tried to reset the cache data on Extended standby controller app and then tested, but still was the same.
Anybody can confirm, if the behavior is the same in your Z2?
1 REPLY 1
JoeMok
Visitor
i facing same issue about the wifi keep on... even though i turn off the wifi... but keep showing me the wifi keep switching on...
Admin please Fix this problem...
