i have been using xperia z2 for like 4 months and this is the second time i am facing this problem with wifi.. First and the foremost the wifi router i am using is working perfectly and i can use the internet connection with my laptop...when connected to my z2 the download arrow is not glowing..only the upload arrow is glowing..and i cannot access any web page through my phone..
Maybe a stupid question but do you know what your wifi channel number is and is it possible that your router security is blocking your phone - You may wish to access your router settings and disable it and also maybe change the channel number to 6 or which ever number is best suited to your country
i have been using the same wifi router for like 4 months and never face this type of problem...and that too i have used the same for my xperia sp...i never faced this kind of issue...and the thing you said to disable the router security and change the channel to 6...there is no such option...
and also my router automatically configured the connection...so there is no option to change the channel and also to disable the security..
I assumed that every router has advanced settings for IT technicians - Every router I have come across has and I've seen a few as it's what my company does - IT Security
ok i will let you know tomorrow as i have complained about this to the company of the router and they are sending a tecnician tomorrow...
