Screen blackout / screen problem
kumarakash655
Visitor
yesterday, Screen of Xperia M dual, started showing vertical and horizontal continuos lines. I tried rebooting. It worked for first.
Then I restored factory settings, it worked for a while.
Then again, from this morning, the screen is completely black and nothing is appearing on the screen.
Tags (1)
1 REPLY 1
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable.
If this does not help,you have to stop by a sony service.
alexdon
