SD card problem
XEL
SD card problem
Hello, I have an SD card problem where It cannot be read anymore. Whenever I connected it to my PC, it only shows [Internal Storage]. When I go to setting>storage, The "Mount to SD.." is greyed out and I can't click it. I tried the sd card on my other phone, It too has the same problem. Is it corrupted? pls anwer Slightly_frowning_Face
3 ODPOW. 3
profile.country.RO.title
_alexdon_
Have you tried to restart your device after inserting the microSD?
alexdon
XEL
restarted a bunch of times already and still the same, I forgot to mention earlier that it happened after I transfer something into the sd card and when I disconnected and reconnect, it doesn't shows "external storage" anymore.
_alexdon_
Connect your microSD card to your computer and format it.
alexdon
