Hi
Ive had trouble with my phone since the android kitkat update. It shuts off. My earphones that i got with the phone wont register that they are plugged in. My diagnostics app in my phone doesn't work either.
I'd really appreciate it if someone can help
You have to perform a software repair using PC companion.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable.
