Hi
Sony Xperia Tipo ,single SIM,which is being working fine since 2012,all of sudden dead in last week.
Unable to boot the set.Tried with pressing both Volume and Power Button didn't help.
Since the phone is purchased Out of India ,no Authorized Service Center in India is accepting to take the Complaint and Service it.
Any valuable suggestions to fix this issue.
Regards
Raj
Have you tried removing the battery and using only the usb lead connected to a power source to start the phone - When it is plugged in do you have any lights on the device
Yes tried removing battery and Connected to the Power source ,Switched both Volume and Power button,But still no luck
any suggestion's are welcome...
Sounds as though you need to visit a service centre http://www.sonymobile.com/global-en/support/contact-us/
