Sony Xperia Z 1 back side glass panel has broken
RakeshNandi
Visitor
My Sony Xperia Z 1 back side glass panel has broken ..i have already visited Sony Authorized Service Centre and they told me to pay Rs. 18,000/- to replace this mobile for a newer one but i want a better suggestion ..Can i chnage the back side panel ? if i can then how much cost it will ? My handset is under warrenty period it just 9 months old and also please tell me if i won't  replace the back side glass panel it will efect on my waterproof facility !2014-08-12 12.42.27.jpg
2 REPLIES 2
Hampus
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You would do best by contacting your local support team in this matter since prices and warranty may differ from market to market:
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
Thommo
Genius
You can replace this yourself and doesn't cost much at all - As for waterproof you need to have a vacume test performed and with a cracked back pannel I very much doubt it is waterproof
Here's a DIY video on how to replace
Replace glass pannel but you will probably find one closer to home
