I am having the same problem! even when I mute off vibrations in the sound settings!!! its like the vibration device touched the speakers and that squeaky sound comes out, HELP!!!!
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
That sounds quite odd. Have you tried to remove the vibration feature for the keyboard? Under settings > language and input > settings icon next to Xperia keyboard > sound and vibrate.
Does it still have the squeaky sound when you are typing?
In that case I would suggest that you try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
I reeboted in safemode and nothing. all my sound settings have sound and vibration off in the settings options. please help
In that case I suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
http://www.sonymobile.com/global-en/support/contact-us/
You could try to repair the phone software using PC Companion before handing it for service:
http://www.sonymobile.com/update
In PC Companion, press start on Support Zone > Start on Update the phone/tablet software > click on the blue highlight (Repair my phone/tablet). Do this without the phone connected. Follow the instructions on screen to perform the repair.
Before repairing the software in your device you may want to backup your information first. Check out this topic for more information on how to:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
