I have recently purchased Sony Xperia L, the phone is excellent and has no issues until recently i found a bug in the phne's battery. Whenever my battery reaches around 50% it suddenly drops t0 43% or 45% in a minute when the phone is idle. I dont use any battery doctor type of apps but i do use Clean master. Suggest me a solution ASAP. Thanks!
Remove any kind of task killers or battery savers and monitor your device.
I deleted clean master but the same issue happened again
Even I am facing same issue. At onemoment it shows 20% and next moment it shuts down.
Perform a software repair,see if that helps:
http://www.sonymobile.com/gb/tools/pc-companion/
Tried it but no luck 😕
In this case,stop by a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
