Hallo
How can I synchronize the two calendars from phone and google-calendar?
On the googlecalender i can touch on the top "Einstellungen" (settings) and than "Synchronisierung mit Mobilgeräten" (Sychronization witz mobile devices), than "google Kalender für Androidgeräte" (synch google calender with your android device), "Kalender für Android 4.0+ (telefon" (calendar für android 4.0+(phones)), than Kalender aufrufen und synchronisieren (sync & display calendars), than it is written that I should call the google-calendar, than is written that at the bottom of the sceen below "to synchronize calendars". But there is nothing written on my screen.
If i try to do it with my phone:
I go to "Settings", than to "account", than to "google" than to "sychronize calendar immediately". Than is written, that it is sychronized. But it is not.
Can you help me?
Hello again me 1 hour later. No the phone calender took the dates from the google calendar, but can it no do it in the oder way from phone to google?
open the calendar > menu > settings > calendars to display
Thank you fot the answer, but it does not work. It takes the calendar from pc to mobile but not from mobile to pc.
Anytime
