Check if there's dust or anything inside de 3.5mm connector
Hi Skuzzbag,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
By reset do you mean you performed a Factory Data reset or simply restarted the handset?
If you only restarted, this may be an application fault, try clearing the Smart Connect application first.
Menu > Settings > Apps > All > Smart Connect > Clear Data.
Let us know how you get on.
Thanks.
I performed a complete factory reset in order to resolve poor performance (this was resolved) but was hoping that it would also resolve the headphones issue.
Thanks,
Rich.
Just to clarify, you still have the issue after performing this function on the device?
