Volume on headset not working
KernowMan1968
Visitor
I been having this trouble for months
I have a MH750 headset and the volume has stopped working
I tried a different headset and still have the same problem
Is there a setting on the phone that switches it on and off or is the earphone socket damaged?
Any help would be grateful
2 REPLIES 2
needhelpplz
Visitor
It Depends if the phone Find's the headset or no Try doing the Smart Connect Settings Turn on the Headphones / Headset Settings in Smart Connect and plug in the headphones / headset if it find's as Headphones / headset Plugged in Its not the Earphone socket . If it does see well try lots of diffrent way turning up the volume
KernowMan1968
Visitor
Hi
On the smart connect theres only "None and Track ID"
Nothing about Headset or headphones
