Xperia E C1505 Hard Reset & Touchscreen not Responding
itssnika
Visitor
Hey guys, first of all I have a issue that my phone is going mental. It presses buttons and apps itself, then on the lower right part of my touchscreen it isn't responding at all. So i tried to hard reset it because I believe its the issue with the hardware as doing the factory and setting reset it does not give any result to this problem. I've had problems doing the hard reset on my phone as the (volume up+power key combination) does not work at all. I've tried all sorts and nothing works. Most of these issues were faced with different Xperia models and this one's tricky...I had no clue what else to do anymore.
Does anyone have a solution, or atleast has someone been through the same?
Thanks for you reading
3 REPLIES 3
Thommo
Genius
Do you have Glove mode enabled?
itssnika
Visitor
I don't have glove mode enabled. However the phone works with gloves and those touch stylus', but I don't use those as they're time consuming to be honest.
At8f
Visitor
same problm with me
