xperia e3 dual ear speaker not working
santoshbatulla
Visitor
i have brought my xperia e3 dual weak before but now the ear speker is not working can any one helpme?
please say what is the solution for it?
2 REPLIES 2
Thommo
Genius
Try performing a system repair as this will often fix issues - This will factory reset your phone, If that fails then either return your device to the place of purchase or contact Xperia care to have you device inspected http://www.sonymobile.com/global-en/support/contact-us/
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
Uliwooly
You can try to repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
