xperia L overheat problems
xperiaeugene
Visitor
i have questions please help me -thx
*is xperia L overheating normal?
*it is okay to use xperia L even if it is in oveerheating condition?
       *are there any negative effects in my phone if  i continously use it in overheat status?
4 REPLIES 4
Uliwooly
if your phone overheat it will shut down, it is normal that your phone gets hot when you use it or charge it.
Cot88
Enthusiast
When the device overheats?
Overheating during gaming session or surfing internet (especially with 3g data on) is normal.
Also the phone becomes hot when GPS is on.
If your xperia L has the same issue even in idle/standby probably there is a process that doesn't work correcty
Try to reset unit to factory conditions
if issue persists try to contact sony for a repair
Uliwooly
gohilvishal912
Visitor
Hi....my phone also gets overheat & gets shut down automatically... Frequently.... What should I do....please help
