How can i solve my xperia p sensor problem? I can't play any sensor game such as moto race,tample run...
please give me a solution.....
Repair with SUS or PCC.
Try typing on dial pad *#*#7378423#*#*
and go to service test.
navigate though accelerometer. click it
and look at the number if they are changing if you movie it.
and if you put it on a flat surface. it should be 0.
AUTO ROTATION PROBLEM:
TRY THIS AT YOUR OWN RISK OR ASK PROFESSIONAL !!!
I solved it by opening the phone and then tapping the gyro sensor IC a bit. It is the first ic on top of mother board after opening back. After that auto rotate started working and no problem uptill now.
This works very well with my xperia P. Thanks.
