xperia sp freeze while charging
avneetsp
Visitor
After the 4.3 update xperia sp freezes when plugged in charging .
it takes 5 to 8 seconds to recover . and also the network takes too long to come back after being gone.
1 REPLY 1
Thommo
Genius
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
