xperia u boot problem
martineriksson0
Visitor
Hey
I accedently downloaded a kernel zip on my phone and I flashed it in CWM recovery when I had about 10-15% battery but it worked. When I selected reboot system in CWM recovery it turned off and then it didn't turn on so I thouhgt it was the battery so I charged my phone all knight but it still didn't turn on. So I tried to flash the stock 4.0.4 rom using flashtool but I can't go in to flash mode. It seems like my phone doesn't charge after I flashed the kernel. Is there anyway I can fix it or do I need to send it in for repair? If I send it in to repair how much will it cost?
Tags (1)
5 REPLIES 5
Thommo
Genius
If you have flashed it ie: CWM and it has failed or caused an issue then because of that you will have voided any warranty and as a result of that would have to pay for repairs - You have tried to flash it using Flashtools but as it won't enter flashmode I would think the eeprom has been corrupted
DILS
Visitor
I have problems with my Xperia U start, I tried to restore a backup, but by mistake Icopied a backup of another phone mobile which team goes off and not turn on more,but when I press the power key the only mobile phone vibrates.
Please, if we someone could help me?
Tags (1)
marer15
Visitor
How much does it cost to fix it?
Thommo
Genius
No idea you would need to contact your local Xperia care http://www.sonymobile.com/global-en/support/contact-us/ as prices may vary depending on country and availability of parts
marer15
Visitor
I have fixed it now I borrowed my friends Xperia u and charged my battery and then I flashed stock 4.0 rom and then it worked again.
