xperia z2 Wi-Fi problem
pdf
Visitor
<a href="/t5/FAQ/Wi-Fi-problems/m-p/348104/thread-id/11" target="_blank">/t5/FAQ/Wi-Fi-problems/m-p/348104/thread-id/11</a><br><br>I tried all these solution ( please read linked solutions ) but i can not able to connect wireless network. The main problem is I can able to connect ADSL wireless network but can not connect broadband cable wireless network via Z2. Also I have ipad and iphone which they can able to connect both wireless network with no problem.<br><br>I tried some software from google market but they are not helpful.<br>I'm waiting your help (desperately Slightly_frowning_Face )
17 REPLIES 17
eida33
Visitor
Try repairing your phone by using Sony PC/Mac Companion.
pdf
Visitor
I do not remember how many times I reboot modem. now I'm using fixed ip but still can not connect internet. when I close and re open wireless from z2, it takes 5 mins to disconnects.
Also I used sony bridge ( repair device)
It is so strange, I can connect at my work via adsl wireless but can not connect at home via cable wireless. All of my devices except Z2 can connect normally both at home and work.
I do not know if I have to some tune/fix  for my modem ?
pdf
Visitor
Also I use smartband which is stable but sbh52 headset is not. I do not know when sbh52 lose connection until phone rings. It seems I always remember sony with '' disconnect '' .
But my main problem is wireless connection.
Kuanyu24
Visitor
Could it be that your home modem/router is assigning the same IP to two devices? This can cause the device to keep trying to connect but keep getting rejected.
pdf
Visitor
nope.
tonight, I will re-check if it is possible but, I remember that z2's ip is xxx.11 other devices have different ip
Kuanyu24
Visitor
It sounds like it's your router since you mentioned that it can connect at work to the ADSL wireless. Have you tried borrowing a friends router to test at home?
KazIRahman
Visitor
I had the same problem and i always keep my bluetooth on as i use a bluetooth headset SBH-80 to be precise..sometimes i face this problem..i always turn off the blutooth and reboot my phone normally then after my connection establishes i turn on my bluetooth and works fine..
pdf
Visitor
Yesterday, I tried to repair z2 via sony bridge again ( former mac/pc companion) and it's ok.!
But this time after repairing, I do not get back my back up files ( only contacts) also I do not uninstall unnecessary google apps!
I do not like and use these apps but I'm afraid to uninstall them again ( like keep g+ photos etc ) because of wireless problem.
by the way I do not know which is helpful to solve my problem but I solved it. I try;
2 times repairing via sony bridge  but at second, I do not get my old apps. Also sbh52 connection did not broken for 1 day, this time I don't want to install it's little aps for reading sms/mails from sbh52 because of further broken connection.
Thank you for your help and kindness.
