Hello,
After yesterday's update to android 10 the alarm stopped working on my XZ2. Alarm won't ring at any time. Anyone else came across with same issue? Is there any solution for this?
Thanks in advance
I have the same trouble. What can i do?
I have a similar problem to those reported. When I turn off the alarm in the morning it then rings another 2 times? Why is this happening as I am definitely turning the alarm off each time (not snoozing). This has happened since the android 10 update.
My alarm also goes off multiple times since the update , even though I dismiss it each time
Не работает будильник и не обновляются приложения
Alarm does not work and applications are not updated
gt
Hi. I have the same alarm issue, as well as the timer not sounding either. Hopefully someone in support is reading all these comments. Sometimes I wish you could turn the updates off. I was very happy with my X2 until the last update.
I have two other alarm clock bugs to report (appeared with upgrade to Android 10):
1) The "repeat" option is not working. The alarm is activated/set when it has been modified (or toggled off and back on) but it will not repeat the next day (even though the alarm list indicates that the alarm is set).
2) Side buttons do no longer dismiss/snooze an alarm.
Off topic: I have a bunch of other Android 10 bugs, but I love all the improvements in the new OS so I am happy it was released for this model.
My phone as well! AND! THE BATTERY DRAINS VERY VERY FAST!
I have a "ghost alarm" going off a few minutes after I've turned off the last alarm. It's saying it's snoozed since 11:59 no matter what time the initial alarm was
Hello,
Has anyone also had problems with Android 10 52.1.A.0.532 when it comes to alarms?
When I "Snooze" Alarms, which is set for 10 min, it will go off in 30 seconds despite being set differently.
It is almost as if the alarm setting is ignored by the clock software..
Still no fixes, eh? I just dismissed my alarm 17 times (waiting to see if a mysterious 18th time appears!) And it sure is frustrating not being able to snooze for any known ammount of time; sometimes it's 10 seconds, sometimes it's the full 10 mins... Who knows what it will be!
