Do not detect microsd
Angelylucho
Visitor
Mi telefono si reconocía las tarjetas, pero cambie de tarjeta sd y ya no detecta ninguna ☹️
My phone did recognize the cards, but change the sd card and it does not detect any ☹️
GT
1 REPLY 1
disimes95
Contributor
Hi @Angelylucho and welcome Grinning_Face
Since this is a user-based global forum, we use english! By doing so, we can assit you faster!
I´m sorry that you´re facing that kind of issues!
So, let me see if i understood you: You had an sd-card that worked fine but you replaced it! This is the one thats causing the problem, right?
Can you tell me the specifcations of the sd-card?
