Feature Request for priority apps
GELÖST
Sailor1
Besucher
Recently i heard Samsung has enabled a priority feature .. Like which app we would like to keep in the Memory and which we don't mind getting closed automatically
For example at times I'm downloading something on Chrome and i am using other apps and sometimes i find it that it has been closed automatically because of less ram... So i would set it as a priority to be kept in memory so that my download does not get interrupted
Hope i explained myself well.... Please respond official mods
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Jonas
Meister
Hi @Sailor,
That sounds pretty awesome! Slightly_smiling_Face
Basically a feature that makes sure that an application won't be closed down due to opening another application that needs the RAM memory has been launched, and other applications should be closed instead of the application with the set priority.
I can see how this can very useful so I will make sure to forward this as user feedback!
Do note that I can't make any promises that this will be implemented, but I thank you for your suggestion! Slightly_smiling_Face
5 ANTWORTEN 5
NeoBeum
Enthusiast
You're wanting a toggle for keep alive/permanent background service.
You can half bake selectively keep apps alive by keeping the app window in the Overview Soft Key Screen, and not swiping to close
Sailor1
Besucher
That doesn't work always... I want a priority mode kind of thing
Jonas
Meister
Hi @Sailor,
Sailor1
Besucher
Thank you ... Yes you got my point exactly
It will be really helpful in multi-tasking ... Glad to see such a quick response and hoping to see this feature in future updates for XZ .. cheers
Jonas
Meister
You're welcome! Slightly_smiling_Face
Let me know if there is anything else!
