Bonsoir à tous
Comment mettre mon tél Sony xperia xz prénium en noir et blanc ??
Par avance merci pour votre aide de vos reponses
good evening everyone
How to put my Sony xperia xz prenium phone in black and white ??
In advance thank you for your help with your answers
-GT
This is a an English based forum, please post your questions in English so everyone can help you.
Unfortunately there is no option to use your XZ Premium screen in black and white (I suppose that is what you are asking).
If you are looking to take black and white photos or videos that isn't also available in the camera options, you can however turn color photos in black and white ones with the photo editor in the options of the bottom menu available in the photo screen.
Oui c'est bien ce que je demandais
Merci pour votre réponse
Yes that's what I asked
thank you for your reply
-GT
@Sacha06 go to Settings > System > About phone, find the field caller Build number and tap it 7 times. this should unlock Developer options. then go to Settings > System > Developer options, and find a setting called Simulate colour space (it should be in a Hardware accelerated rendering section) and set it to Monochromacy.
