How to record screen?
Hensly
Visitor
3 REPLIES 3
profile.country.PT.title
NunoSEN2
Hero
Hi @Hensly;
There is no native function to record the screen but you can find several apps in Google Play that have that function.
StuartOswald
Visitor
Coming from a Z5 Compact I am sad to find out that Sony removed the native function to record the screen.
Can anyone recommend an app as close to the Sony stock one?
najodleglejszy
@StuartOswaldI can't really think of one similar to the screen recorder by Sony, but you can check ScreenCam (https://play.google.com/store/apps/details?id=com.orpheusdroid.screenrecorder). once you install it, you can add the screen recording button to quick tiles area (where WiFi, Bluetooth, flashlight etc. toggles are located in) for quick access.
